K24 ABY Boosts high
  • pnanassy
    • Dec 2004
    • 287
    • Country: Hungary
    K24 ABY Boosts high
    I just finished a very nice S2 Coupe VEMS project with great results.
    The car is pretty standard except it extremely loud 76mm exhaust system.
    The engine sounds really good,every small part is in its place,thats unique where i live.
    Customer wanted VEMS ECU as the first step to his distant 400-500HP goal in mind.And stock behaviour in all conditions.E85 was used as fuel,and since the stock injectors are so small i put a set of 630/720 Siemens dekas in.
    Using 1.1.70 firmware and a selfmade Plug and Play VEMS ECU,we tuned two maps street and race.They have different idle,fuel,lambda,ignition and motorsport settings.
    Car was flawless in its stock form and did the 1/4 mile in 14.1@153kmh
    Just swapping the ECU,the injectors,and fuel,the car now passes the quarter mile in 12.8@170.
    Fuel consumption is down to 12-14 liters/100km on E85.Previously it was using the same amount of petrol.
    Peter
    Peter Nanassy
    Custom Engine Management,and Electronic Fuel Injection solutions supplier , contact me for details.
    http://www.carstyling.hu/car_shower.php?id=19845
    http://www.youtube.com/watch?v=FYOVA_285Rs
    Great work Pete, you've been quiet recently I haven't had any emais from you
    E85 looks to be awesome stuff, wish it was widely available in the U.K
    • pnanassy
      • Dec 2004
      • 287
      • Country: Hungary
      Hi Jamo,
      i tought i answered all your questions.
      If there still something i missed,please send it to my email and i will take a look at it.
      Yes,E85 works well,fortunately we have enough here
      Peter
      Peter Nanassy
        That's good going on a stock turbo! Mine was early 13s when I had a play a year or two back, would be interesting to see what it'll do now.
        What's required to go E85 other than new injectors and a remap? New fuel pump, 044? How does the fuel system cope with things like seals?
          Originally posted by pnanassy
          Hi Jamo,
          Peter
          LOL that's not what I meant
          How much more ignition timing were you able to put on the car running E85?
          • Bram
            • Aug 2006
            • 2582
            Nice work Peter. What boost levels are you running with the stock K24 turbo?
            • pnanassy
              • Dec 2004
              • 287
              • Country: Hungary
              Ah,ok,sorry.Just too busy with owdis
              Car was not really tuned to the "edge",its just a safe map.If customer decides to go hardcore,we will see wheres the limit.
              Peter Nanassy
              • pnanassy
                • Dec 2004
                • 287
                • Country: Hungary
                Fuel pump is stock,lines also.Filter needs change.I hope the seals will hold.
                Peter Nanassy
                • pnanassy
                  • Dec 2004
                  • 287
                  • Country: Hungary
                  Boost is 1.5bar as soon as possible,and it falls back to 1 bar at redline.
                  Peter Nanassy
                  • pnanassy
                    • Dec 2004
                    • 287
                    • Country: Hungary
                    Peter Nanassy
                    • AndyP
                      • 6049
                      Great work, are you planning to put it on a rolling road?
                      • pnanassy
                        • Dec 2004
                        • 287
                        • Country: Hungary
                        Im not sure about that.
                        Peter Nanassy
                        • EspenW
                          • Apr 2007
                          • 1534
                          • Country: Norway
                          The seals will be just fine. Change the filter after a couple of tanks.
                          1994 80E Avant
                          1986 2L Golf 2 on Alcohol
                          • Braun
                            • Nov 2008
                            • 53
                            • Country: Hungary
                            Hi All!
                            I am the costumer!
                            Peter!
                            Here a thank you,your work!
                            The car flawless,nice running,and,i am satisfied.
                            Been better,than I expected.
                            Thnx!
                            Mikor vésünk kicsit még a gyújtáson?
                            95' S2 ABY,Arctic Silver Metall,Vems,3076,Tilton,Carillo K1,JE Pistons,...
                              Sweet Nice to see another stock turbo car doing something a little more than expected
