I'm looking for a new ignition distributor (cause I have broken mine) and I can't find it in the VAG market. It is for a 3B engine. May be you have a good adress (except 034 motorsport which is very expensive for me)
and do you know wich part do you have damaged in it??
for example in the past i had broken the metallic/plastic rotor arm and with a very few money i replaced this part + the distributor cap...and no it is like a new one
RED Mitsubishi Lancer Evolution VI TME nº 16 of 250 BLACK Mitsubishi Lancer Evolution VI TME nº 189 of 250
I'm not 100% sure , but think that you can use this metallic circle from other audi distributor rotor.. think from 2.3 10v distributor. try find some and mesure the size.
