alloy radiator options?
  • s2driveruk
    • 12696
    Looking to see if there are any proven options on replacement radiators which are more efficient at cooling than the original?
    I've deleted the aux some years back and never seen any issues but starting to think maybe th original main radiator is coking up and reducing it's efficieny slowly. Especially in the heat of summer.
    So, has anyone found an alloy radiator which is plug and play? or anything close?
    Car is running with a/c so would need to alloy the condensor to piggy back it too
    David
    1992 3b S2 Coupe
  • quattro
    • Dec 2004
    • 768
    only plug and play one that i know of is 034MS
    Probably the longet S2 project in history EVER!
    • Rusty
      • 18953
      Give me a shout David, I've been looking at these for a while and have a supplier that I can use
        Allisports do one although they aint cheap
        • s2driveruk
          • 12696
          Andy, you down at Coombe in a couple of week btw...?
          The pricing variations are pretty big as you say Jamo....all we'd need is th ensure that the depth increases slightly and there is a bit of room to allow that and keep the conneor locations in the same place and job done.
          Might pop a bit of water wtter in mine as i seem to remember when i used that a few years back it managed to remove a load of crap when i drained it. was pretty good stuff too actually for £10
          1992 3b S2 Coupe
          • europeanme
            • Oct 2005
            • 3817
            did anything come of this request??...
            • s2driveruk
              • 12696
              nope, work got in the way unfortunately and havent been close to the car or this place much in recent weeks. Do want to explore some options though
              1992 3b S2 Coupe
              • Rusty
                • 18953
                I really must send my spare off to get a proper quote... Got a few things like this to sort but not had the time to sort them
                • s2driveruk
                  • 12696
                  you're in good company Andy believe me
                  1992 3b S2 Coupe
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    I think that for the price of the plastic ones that forum members use they would find it hard to bare a Aluminum unit price the core is the expensive part for a good core the size of the OEM one your at £100+ before you welded the end tanks and inlet and out let pipes and also a bleed valve. Its going to be £250+
                    Chef
                    • europeanme
                      • Oct 2005
                      • 3817
                      i have had a quote for a s2 rad from TPS is £254+vat!!!.....so this is definetely worth a look for a suitable replaecment...
                        GSF should still be doing the behr rads, it's a special order however. I haven't asked my contact at GSF about them in ages since I 1st got the original rad
                          Budget £400+ for a decent alloy rad IMHO. Its never going to be a volume item and you pay for decent craftsmanship building a good one.
                          • europeanme
                            • Oct 2005
                            • 3817
                            my only concern with GSF is that with is being a special order item, i may end up with a nilssen one!!....as they are an S2 radiator and under the trades description act they have acheived their end of the transaction!!..
                              eh? not really if it's specified a behr rad and they supply the wrong one it's their fault
                              easy to see when your at the branch, behr = plastic end tanks nissens = metal tanks
