Hi everyone. Right I have got my s2 up and runnin
but and there's always a but! Very poor tick over, revin up an down and sumtimes cuts out. So I have done:
cleaned maf, was much better now but still messin about an cuttin out from half throttle to idel.
changed idel valve, no difference
changed brown sensor in manifold, better again but revs going up am down on tick but not offen but still cutting out
I think in my eyes that the return punger on the throttle body may be to weak? Goin to change that 2 moz nite. But other wise once off tick over revs lovely.
And also it's like it's stuck in limp home mode because won't even spool up properly and only gettin 6 psi. Now I have been told that the pipe on thr n75 valve which goes into the standard intake pipe between maf an turbo can be left out without connecting it to anything?? As I have had to make custom pipe work.
Engine spec
je custom 82mm pistons
eagle hbeam rods
arp top an bottom
muti layer metal head gast
3b fly wheel
034 race coils
standard aby intercooler but only at mo
5 branch manifold with hybird kkk 26/27
ecu had 280 chip before rebuild
car always mucked around with boost before rebuild, if I was town drivin and engine temp got around 80 just over then I would get 6psi but then went out of town onto the wide open roads 1 or 2 miles temp would drop to about 60 ish an off I wud go 22 psi just like fickin a switch
any ideas wud love to hear. Tryin to get her on road for 1st of next month
cheers tom.
Engine spec
eagle hbeam rods
arp top an bottom
3b fly wheel
034 race coils
cheers tom.
