I am nearing the point where i can finally drop the motor in my coupe quattro(knock on wood). However there are quite a few questions popping up before I do so. Your patience with my post will be appreciated.
First question:
I can't seem to find the active charcoal canister for the aby motor?
I have checked pictures, went through etka.
What type of setup is used?
My coupe quattro has it on the right side of the engine bay next to the coolant tank.
A fellow american who did the swap, I am noticing ran another line to the left of the coolant tank and to the carbon frequency vavle.
I am thinking this is my easiest solution?
Also.. My coupe quattro had the carbon frequency vavle on the carbon canister, and the wiring/plugin was on a seperate harness for the coupe quattro than the Hitachi/motronic harness.
I am waiting for a reply from some fellow people who did the swap, But I am hoping I can just leave the plugin undone, and rely on the aby plug in?
Next question:
actually I am a little busy.. but I will get back to this.
Thanks
Josh
First question:
Next question:
Thanks
Josh
