Uh Oh.... I smelt Burning Oil....
  • Reno
    • Jul 2010
    • 22
    Ok so just now I went on literally a 1 min run down the road in the ur quattro, got out and smelt Burning Oil, popped the Bonnet and this is what I found:
    Note the ring on the side of the Head in the last 2 Pictures.
    Any Ideas?
    Cheers.
  • spink
    • 4382
    looks like your rocker gasket is leaking but that ring looks a bit weird,is it trapped between the inlet manifold and the head?
    • Reno
      • Jul 2010
      • 22
      Apparently it's part of the Manifold to Head Gasket thats not used/required.
      • curlyks2
        • 1069
        Agree - had this, complete with smell of smoke when the oil dripped down onto the (hot) exhaust.
        Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
        • zer matt_c
          • Dec 2006
          • 24
          You have to be careful not to over tighten the rocker cover especially if its the later rubber type with the crush washer type re-enforcements (unlike the earlier cork type with no re enforcements).
          hope this helps.
          84 WR with an extra 10 valves.
