UrS4 Hall sensor in the Tuna can (in the distributor casing)
  • Billman
    • 4129
    Hi, how can i remove the hall sensor from the distributor can? There is the metal disk that is pressed on the shaft.
    thanks
    Go Holset or Go RS4
  • mcandmar
    • Apr 2004
    • 5118
    On a normal dizzy its part of the main shaft, to get the shaft out you have to press out the pin and remove the gearwheel.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • Billman
      • 4129
      this is from a distributorless engine but with the hall in the distibutor housing.
      Go Holset or Go RS4
      • AndyP
        • 6049
        It's the same I would imagine, drive the pin out, remove the drive gear and the whole shaft lifts out from the top exposing the hall sensor.
