7A Flywheel pin location
  • Billman
    • 4129
    Did someone else noticed that the crankshaft positioning sensor on the 7A flywheel is on different location than on the RS2 i.e.?
    Go Holset or Go RS4
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    Negative. I have noticed, that it's on same location as AAN flywheel, and my AAN works just fine with 3b flywheel.
    What has led you to such conclusion ? This forum revealed many things I could't possibly think possible - to be possible . So I can change my mind if you have some proof that those are different.
    Sau
    • Bram
      • Aug 2006
      • 2582
      I believe my 7A FW has the pin at the same spot as my old ABY FW
      • MrVain
        • Oct 2008
        • 189
        Some 7a have it on another location ive heard...
        • Billman
          • 4129
          i have heard the same and wanted to see if it was right
          Go Holset or Go RS4
          • kwlw
            • Sep 2004
            • 1025
            Ok, if it's true, then how comes, that Audi lists only one flywheel for 7A 034 105 270K ?
            Flywheels with different pin locations should have different part numbers :mischeif:.
            Sau
            • pixsaudisex2
              • Sep 2004
              • 3110
              Do some have more pins though.,
              • zpix
                • May 2015
                • 8
                • Country: Denmark
                ETKA Says 7a flywheel is 034 105 270K
                But the 7a flywheels on the internet have part number 034 105 271 c (Same as NG, NG just don't have the pin)
                So Theres a flywheel "034 105 271 c" with timing pin (7A) and a Flywheel "034 105 271 c" whitout pin (NG)
                • vidar skotheim
                  • Apr 2005
                  • 566
                  • Country: Norway
                  And machining and balancing also missing on them
                    Who are you going to believe eBay or ETKA? 034105271C cannot be found in ETKA. However, you might be able to find this that shows that the NM and 7A flywheels have the same PN and that the 3B and ABY flywheels are different (I know the ABY is a dished flywheel).
                    • zpix
                      • May 2015
                      • 8
                      • Country: Denmark
                      ETKA sould not lie? but the flywheel i got from my NG engine is neither a 034105270E or 034105270EX but a 034105271C
                      And funny 034105271C dosn't exist in ETKA, when you Search 7a Flywheel on here the most of them have P/N 034105271C (havn't found the 034 105 270K)
                        Originally posted by zpix
                        ETKA sould not lie? but the flywheel i got from my NG engine is neither a 034105270E or 034105270EX but a 034105271C. And funny 034105271C dosn't exist in ETKA, when you Search 7a Flywheel on here the most of them have P/N 034105271C (havn't found the 034 105 270K)
                        Originally posted by driftin jo
                        Its very confusing, let me try and explain. Part number 034 105 271 C, I have had lots of these machined to 3B spec, all the ones I had did had the timing pin in. I think the problem we have is that a lot of the flywheels have this number ( 034 105 271 C ) as this refers to the cast part, not the engine number directly, therefore it may not have the pin in some cases. I have had these from 7A engined cars and other people have said the number is wrong and yet I have removed 3 of these from 7A engines personally ! I think somewhere along the line Audi just decided to use one casting and add pins that were required for engines that needed it. .
                        I think THAT is your answer. Audi started with one casting and then made modifications to suit the particular application. It was the *modified castings* that got the proper PNs, like 034105270E, 034105270EX and 034105270K. This is very similar to the 3B, AAN and ABY exhaust manifolds - they have a 9 digit casting number but that is not their part number because the actual part had studs added to it before it went in the parts bin for retreival and installation.
                        • zpix
                          • May 2015
                          • 8
                          • Country: Denmark
                          Now I get it
                            Now I get it
