Aan runing rough between 4-4500 rpm. any ideas ?
  • nemilosu
    • Nov 2008
    • 196
    • Country: Romania
    is like have detonation or something, and after 4500 rpm is runing like a non turbo engine.
    cheers.
  • Knight Rider S4
    • 3541
    Coil issue? or POS
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • nemilosu
      • Nov 2008
      • 196
      • Country: Romania
      thanks.
      i will check tommorow.
      another ideas are welcome.
      cheers.
      • Sleeper_Avant
        • 2372
        hall/cam sensors can give this problem, more noticable in higher gears
        if you have diagnostic plugs wired up, check to see if the knock sensors are giving massive ignition retard
        1993 URS4 Avant Emerald Green 350+bhp
        1991 Ford Sierra Sapphire 4x4 in Magenta
        BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
        • nemilosu
          • Nov 2008
          • 196
          • Country: Romania
          i made a wire diagnosis.
          codes are:
          1111
          1231
          2324
          2312
          4414
          firt is always since i have the engine
          the second i know because is not mounted
          the red onaes may be the problem ?
          the coolant sensor and the maf are almost new.
