Any Diesel experts?
  • Knight Rider S4
    • 3541
    Any Diesel experts?
    Looking to see if anyone can help with this problem I have
    Rebuilt diesel engine up in a A4 got it all in started it up fine no problem then the next day went to get it going and no joy at all have checked timing to see if it had slipped a tooth but all good , fuel getting to injectors but the glow plugs dont seem to be getting power , check relay first and its fine ..Its like it has immobiliser fault of some sort as it turnover it like it wants to start but just wont , have run a live feed through the glow plugs just to see if I could get it to go but same thing , it offers but just doesnt run ...VAG.com does show anything
    Have swapped over ecu and the things that you would think it would be but still pinning it down to immob
    Is there a way to cancel this out or is there a relay that I am missing
    Steve
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
  • Sleeper_Avant
    • 2372
    what TDi is it?
    have you just rebuilt the origional motor or swopped complete one?
    if its a 2.5tdi i know a lot about them
    my A4 used to be one lol
    1993 URS4 Avant Emerald Green 350+bhp
    1991 Ford Sierra Sapphire 4x4 in Magenta
    BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
    • Knight Rider S4
      • 3541
      1.9tdi 1998 Non PD pump
      93 S2 Avant Parting
      91 URQ RR
      02 A4 tdi Avant
      • Sleeper_Avant
        • 2372
        easyest thing is
        a) is immob light flashing on dash?
        b) squirt a BIT of easy start or brake cleaner in the inlet and see if it barks up
        • s2_wot
          • Aug 2006
          • 2178
          Steve, if its an immo issue I think it will allow the car to start and run for approx 1 second and then cut. With my Passat this happens from time to time. The fault is a wire that crosses the top of the steering column. If the steering is lifted to max position this cable gets pinched from time to time and prevents the car from running.
          In vag com you can run through a few relays and solenoids with the engine off but with the ignition switched on.
          Fuel cut off valve not working correctly?
          Shane
          • Knight Rider S4
            • 3541
            Lights on the dash yes ,
            Will check the steering wheel as that is possible, were is the fuel cut of valve ?..!!
            Will do a output test with vag.com and see what is it shows
            Chhesr for the info guys
            93 S2 Avant Parting
            91 URQ RR
            02 A4 tdi Avant
