Oil Deflector
  • nigelm
    • 150
    Oil Deflector
    PN 034 103 553D
    This is the flimsy plastic insert that fits under the cam cover below the oil filler cap. Mine is broken. My question is - I presume it's fine to run without one?
    Currently on 'Back Order' say TPS/Dealer
    Unless anyone has one lying around?
    Thanks,
    Nigelm
  • GazzaG60
    • 4133
    yes. you may get wet if you open the cap with it running though.
    • nigelm
      • 150
      Thanks for the reply ,
      I guess I'll have to run without it for a while.
      Quick further question - do I need a new gasket every time I take the cam cover off - or only if it sems to be leaking?
      Nigelm
      • GazzaG60
        • 4133
        they always leak. pita to get sat right.
        if its not the edge its the middle.
        • Flat on my back
          • Jan 2007
          • 2449
          A careful smear of Molykote 55 may help...not tried this yet.
          Spec...
          Carlos.
