I have an ABY coupe and all was well, but its developed a small reduction in power, I would call it a hesitation, so I took it to my local Rolling Road where its been before and sure enough when they overlaid the graphs its lost about 25 - 30 hp, but didnt really help with a diagnosis as it was just a power run.
I've lived with this for a while but would like it resolved now, what I know is....
Homefried V stream running 1.5 bar
No boost leaks (tested)
No fault codes
New Bosch plugs
New N75
New recirc valve
car pulls strong then at about 4000rpm onwards hesitates (no missfires) to the red line
Someone suggested that it could be detecting false knock and retarding the timing (I only run it on Tescos 99 Ron)
My friend has VAG COM, we did some runs today but I dont Know how to interpret the info and it will not let me upload the file (Excel) but looking at the timing its down to 5 or 6 deg at the top of the revs, is this right ?
The other thing I noticed is the Atmos Pressure changes between 1016.4 and 1012 on a flat road, (is this relevant)
I can have another go on VAG COM but what should I be looking for.
Any advice welcomed
Thanks
No fault codes
New Bosch plugs
New N75
New recirc valve
Any advice welcomed
Thanks
