I'm swapping another 7A into my coupe thats only covered 40k miles. Its not been run for 16 years as its been sitting in a warehouse. Seems perfect though, has had plenty of oil down the bores while its been standing. Is there any sort of "running in" proceedure I should go through with it?
Planned to turn it over for a bit on the starter to prime some oil through the galleries and onto the bearings etc - otherwise just take it easy for a few hundred miles?
Engine looks mint, still got most of the original paint on the block and has cleaned up to look almost new. Going to replace the front and rear crank oil seal while its easily accessible, new water pump, idler plulley and cam belt.Took the sump of which was still clean inside - not even any oil staining. I'm fitting a 20vt windage tray I've got lying around and replacing the sump gasket(s), and also fitting a 3B oil stat housing and oil cooler to keep temps under control on track.. ADI here we come
Any advice welcome
Any advice welcome
