If I will put AAN ECU on ABY engine it will work?
ABY with AAN ECU
It will be fine , I've done it before when my ABY one was away for chipping, as long as they are the same type as in both none immobiliser ones.Comment
You can tell by the numbers on the ecu that you took out if it was immo or not , haven't got the numbers to hand right now but I think its suffix b/c that are immo ones someone else will confirm I'm sure .Comment
551A/551AA/551B = no immo
551C/551D/551E/551F = immoComment
