Need good electrician...
  • lee_mac1
    • Aug 2010
    • 10
    the black box behind the ignition key they are about £30.00 from your audi dealer if you are getting all the lives from the back of the switch then you more than likely have a brake in the feed form the switch to the relay hope this helps
    lee
    • spions
      • Oct 2009
      • 400
      Ignition switch is working.Or I need diffrent switch?
      • spions
        • Oct 2009
        • 400
        All is switching on except fuel relay
        • lee_mac1
          • Aug 2010
          • 10
          ok trace the exciter wire from the relay ( the one thats dead ) to the switch and run a continuity test on it to see if there is a brake in it i can not find my book and can not remember the color of the wire
          lee
          • lee_mac1
            • Aug 2010
            • 10
            dose you r car have after market alarm ?
            • spions
              • Oct 2009
              • 400
              #21
              No.
              Car starts.But still problem with power to relay.Will check on holidays.
              Problem was cranckshaft position sensor.
              But now find out that 4 and 5 cilinder don't have pressure.
