Baffle plate & windage tray
    I'm fitting a 3B windage tray to my 7A - the 7A has a plastic baffle in the sump, can't remember if the 20vt uses this as well as the windage tray, or not?
    Windage tray seems to fit along with the plastic baffle - do i need the plastic baffle - is it worth fitting both?
    Ta
  • mcandmar
    • Apr 2004
    • 5118
    Plastic jobbie is only in the 7A. Dont see any harm in fitting both, from memory the plastic one stops oil surging to the back of the engine under acceleration, where are the metal plate is more to prevent surging during cornering. They should compliment each other, infact any chance you can snap a pic with the two sitting in the sump?
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
      Got a pic Mark, but won't be able to upload for a couple of days.
      I've fitted both for good measure, if they both work in their own right its surprising the 20vt didn't get both since they fit in the sump together perfectly well.
        Here you go Mark, found my camera lead
