help: camshafts choice..
  • terrybullwon
    • Mar 2006
    • 8782
    Originally posted by brider
    but what could you say about quality of catcams?
    I heard bad things about them and the repairs that were done
    Chef
    • brider
      • Aug 2010
      • 31
      ok - shrick is better? i mean quality
      • repo
        • Dec 2004
        • 893
        By far. Unfortunately also more expensive - although at this age we all should know, quality and price are usually directly proportional.
        • terrybullwon
          • Mar 2006
          • 8782
          Originally posted by repo
          By far. Unfortunately also more expensive - although at this age we all should know, quality and price usually directly proportional.
          Cheap is not good and good is not cheap!
          Chef
            Catcams wear very quickly, I've heard this across numerous non audi car forums as well.
            • Audi_CQ
              • 940
              • Country: Norway
              #21
              Originally posted by Jamo
              4-5k reshimming is a pain, that's how often it needs doing on an I5
              Based on own experience? If so: something is wrong with your parts.
              I needed to reshim only 6 valves on mine after driving for a couple of hundred miles after initial setup and then it's been OK for years
              A lot of both highway use and track days. This with cat cams. As repo said they have had problems with wear, but my last set(replaced on warrenty) was hardened differently and seems to hold up better.
              About cams: don't go to big. It's no use and can "ruin" an engine. Mine are only 254 degrees with 226@1mm. Dynoed 584hp/700nm @wheels on E85 at 1.8bar with 2.5 stroker.
              • brider
                • Aug 2010
                • 31
                ok - thanks all!
                  Look here at cat cams http://audisrs.com/about17096.html&highlight=
                  • brider
                    • Aug 2010
                    • 31
                    thanks a lot!
