Which of these is an OE tappet?
  • AndyP
    • 6049
    One is from my old 3B engine which was as quiet as a mouse and the other is the brand new one from the stroker, which is not quiet!
  • Billman
    • 4129
    I would say the one with the small hole is OE
    Go Holset or Go RS4
    • bigdan
      • Jun 2008
      • 105
      The one on the left.
      • pixsaudisex2
        • Sep 2004
        • 3110
        are they both oe but one is an earlier one and the other a later one,,,
        dont know if you can tell looking at these photos but here is one i cut up. these were orignal aby...
        • pixsaudisex2
          • Sep 2004
          • 3110
          http://www.s2forum.com/forum/showthread.php?t=41038
          you can make out the square shape meaning the one on the right is more orginal than the one on the left thats my guess,,, but due to your thread you know which is which... i heated one up and boy o boy did some stuff fly outta the hole....
            did you use Febi ones on the stoker Andy?
            • Gringo
              • Jan 2005
              • 139
              I`m guessing that the one on the right is the OE one. The one on the left has the small "oil fill" hole wich I`ve seen in a lot of 8V NA engines. In my opnion the one on the left is far superior and more quiet running. The small hole keeps the oil inside the lifter under heavy use, ie since the hole is smaller it`s more difficult for it to escape when the lifter is pressurised by the lobe. It does however require a thourogh "fill up". I usually let them soak on a bucket of oil for a few days prior to install. Unless you follow this procedure you can get a build up of air inside and they will chatter. The one on the right fills up by itself after install, just lube it and let it rip
              Now you see me, now you don`t
              80quattro.com
              • Audiboys4
                • 56
                • Country: Norway
                INA provides the OEM ones I`ve heard......My car had INA lifters one it anyways when I opened it
                Audi Rs2
                Audi A3 Sportback
                Ducati 1098R
