Engine Still missfiring over 1,2 bar
  • S2sedan
    • Aug 2004
    • 189
    As recommended I checked the coilpacks, and there was a spark leak over coilpack number 5. I called the local stealer and they told me that they don`t have the part and it costs like 500 Us dollars. For just only one coil pack. I solve the leak, because When I was back home saturday the car which only missfire at high boosts starts to missfire at all revs. Coilpack was not changed, only repaired, and the high boost misfire continues. PS I changed the fuel filter too. Any one can help me ???
    S2 Limo sold !!!
    M5 E34 with some mods in the garage
    sorry, but much happeir now !
  • Josh-stateside
    • 741
    Do you have vagcom?
    VCDS,VAG-COM,VAGCOM,Diagnose,Diagnostics,DTC,Fault Codes,Data Logging,VW Scan Tool,Audi Scan Tool, VAG Scan Tool,Micro-CAN,HEX-USB+CAN,HEX+CAN,HEX-NET,VAG 11,VAG 12,VAG 14,VAG 15
    If it's misfiring it will show up on fault codes.
    www.s2central.com Check out the diagnostic link in the technical section if you want to blink out the codes.
    josh
    • S2sedan
      • Aug 2004
      • 189
      I already use it, anda no fault except for the chip fault. Do any one knows how many boost a chip S2 must have, can the 250kpa MAP handle more than 1,6 bar ???
      S2 Limo sold !!!
      • Doug_RS2
        • 3847
        I cannot see how vag-com will show up a fault code for a misfire.
        How have you tested the coilpacks at boost? I think you have a coilpack going bad if it is only failing when you get over 1.2Bar of boost. What spark plugs are you running?
        • S2sedan
          • Aug 2004
          • 189
          thats the point the old owner was running on original A3 turbo, sparks with 3 pins on it. I insist that are not corret for this car, running on higher boost. Am I crazy or stupid ????
          S2 Limo sold !!!
          • S2sedan
            • Aug 2004
            • 189
            Doug, do you know the difference between the original K24 S2 turbo to the new K24 ??? Sims to me that the new one is bigger than the original ... Do you think it`s a good upgrade ???
            S2 Limo sold !!!
            • Doug_RS2
              • 3847
              Get the standard OEM Bosch plugs in the car before you do anything else.
              What new K24 turbo? Out of what?
              • S2sedan
                • Aug 2004
                • 189
                The K 24 that we have here in Brazil is cold case .50 hot (i don`t know) So I think its bigger than the original S2 turbo ????
                S2 Limo sold !!!
                • Josh-stateside
                  • 741
                  Some good reads.
                  Josh
                  • S2sedan
                    • Aug 2004
                    • 189
                    thanks josh, but I think I found my problem.... the problem now, is to get the coilpack here in Brazil. At local Dealer they costs about 560 us dollars.
                    S2 Limo sold !!!
                    • Doug_RS2
                      • 3847
                      try www.vagparts.com - they ship worldwide and could be cheaper.
                      • S2sedan
                        • Aug 2004
                        • 189
                        I tried and waiting to their reply, I tried also iberparts@galicianet.com They are at Vigo Spain, is cheaper for me because of the money exchange pounds are very very expensive here +- 5 per 1.
                        Thanks any way.... I should try Roberto at iberparts. he will post toworrow and I`ll receive tuesday here in Sao Paulo, Brazil
                        S2 Limo sold !!!
