Took the S2 for its MOT this morning and whilst getting nice & hot for the cat test a 10mm crack appeared in the plastic header on the top of the main radiator right by the inlet connection spraying a small jet of coolant out. Now cold & the crack has closed to be invisible.
Thinking about drilling a "stop hole" at each end of the crack, dremmeling out the crack and filling with araldite or similar.
Any comments? Any better suggestions? Can you plastic weld this type of plastic?
Looks like a new radiator is around £180 and secondhand one could crack just as easily.
John
John
