hi !
i have audi s2 aby with complet rs2 upgrade and chip (about 370hp, 1.7-1.8 boos).
last days i have big problem with hesitation and/or cut offs and poor runing. when problem started i hardly noticed small hesitation about 4500rpm, but sun it develop in big hesitation at 3500 rpm. it mostly happend at WOT. when going WOT at cca 4krPm car starts to "cut out" like it would be on rev limiter, but it does not lose boost. sometimes car yust can not go over some rpm (caa 4500) but has constant boost.....
yesterday i managed to hit 1.5 bar but today only 1 bar.......
i have allready make list of things:
-boost leak free
-brand new MAF
-no vag com errors
-DV Forge leak free
-wastegate checked
-n75 tested
-new sparks
-pos and coilpack switched with known good set
-intake temperature sensor checked
-vacuum lines checked
has anyone any idea what should i check next ? Knock sensors ? Poor fuel pump or injectors ?
thanks !!
-boost leak free
-brand new MAF
-no vag com errors
-DV Forge leak free
-wastegate checked
-n75 tested
-new sparks
thanks !!
