Dead S2 :( fuel pump?
    If the ECU sees RPM signal (G28) above a certain speed it enables the fuel pump - I logged this in another thread on subject of 'engine simulator' if you wish to learn more details. This is to stop fuel pump in a heavy shunt that stops the engine while ignition is ON. You can only really test G28 with an oscilloscope. Again I have captured that waveform before here - no mystery that its a sawtooth shape derived from 135 teeth per crank revolution.
    The ECU uses the hall signal (CMP/G40) as the gate to define what phase the engine is on for timing of cylinder #1 - the crank position cannot do this alone for obvious reasons. Best way to test G40 is with 5V LED between pin 2 and 0V - it should blink off every other crank rotation. If the ECU doesn't know where the camshaft is, it cannot determine a firing position.
    So in short form -->
    if G28 is dead you get no fuel pumped
    if G40 is dead you get no sparks
      Oh and of course G40 will be gating factor for injector pulses - so that explains why your plugs are dry even with the fuel pump forced on. I bet my left nut you have a fault CMP/G40 sensor. Go LED shopping before you commit though - or buy an oscilloscope if you are feeling flush
        Also - VAGCOM will likely not tell you there is no signal from CMP - it only throws up a fault if you unplug it or short it out.
        You need a LED touching the pins of the G40 plug while cold cranking - if it stays lit all the time then its dead (or your camshaft isnt turning).
        • BrianSmith_S2
          • Jun 2005
          • 1342
          • Home: Northern Ireland Current: British Antarctic Territory
          Well thats 2 items on tomorrows shopping list then... a 12v bulb for checking the blink codes, and a 5v led for putting across pins of the sensor to check its operational and i think i also read somewhere that code 2113 is the one that that would also indicate the cam sensor G40 is knackered.
          Cheers,
          Brian
            #20
            Read my last post again Brian !!!!!!!!!!
            • BrianSmith_S2
              • Jun 2005
              • 1342
              #21
              Yep, im off to maplins at lunchtime to purchase a 12V (blink codes) and 5V led (test G40) to do blink codes and connect to the G40 sensor whilst cranking over
              Btw i think i did read somewhere on google that if the G40 has failed i can connect a wire across pins 2 and 3 leaving the connector disconected to get the car started?
              ADI just a week away and i dont want to miss it this year so hope i can get it sorted in time.
              • BrianSmith_S2
                • Jun 2005
                • 1342
                #22
                Just lost my blink code virginity and it came up with the following
                flash flash....flash.....flash........flash flash flash
                so im guessing that its error code 2113
                i also put a 5v diode across pins 1 (5V) and pin 3 (0V) on the G40 and it lit up with ignition on... when i turned engine over it stayed on constantly with none of the on off flashing as paul described. So it looks like first thing monday i better source a bosch supplier for a new G40 so i can attend ADI.
                • s2driveruk
                  • 12696
                  good luck
                  1992 3b S2 Coupe
                    #24
                    Brian - you need the LED across pins 2 and 3.
                    Pin 1 and 3 will always be +5V... that is supply to the sensor... the signal output is on pin 2... thats the pin that should blink.
                    This gives me an idea about something else by the way.
                    • Audi-Porsche Avant RS2
                      • Sep 2008
                      • 1041
                      • Country: Italy
                      #25
                      I've said this before... let me say it again...
                      The S2 does NOT prime the fuel pump when you turn the key on.
                      The little humming noise you hear when you turn the key on is the afterrun water pump - don't believe me - go put your hand on it while a friend turns the key on.
                      This one smells of camshaft sensor playing up. A 10 pence LED will verify that.
                      To check the fuel pump is working - the only way to be sure is to have someone crank it (while camshaft sensor unplugged) and crack open the fuel line near the injectors.
                      Assume you have checked silly stuff like fuses ?
                      COuld also be a duff relay - number 10 in main panel.
                      Now Paul I understand why I don't hear anything from fuel pump when I turn on ignition key of mine S2. On RS2 fuel pump turn on for some seconds when ignition key turn on?
                      Thanks!
                      Alessio
                      My life and my loves
                      Audi S6 C4 ABT Avant
                      Audi S2 Coupe ABY
                      Audi S2 Avant
                      Audi Cabriolet 2.0E
                        #26
                        AFAIK - RS2 is same as S2 in this regard.
                        • BrianSmith_S2
                          • Jun 2005
                          • 1342
                          #27
                          Yep, thanks Paul.
                          I re did the test on the G40 properly on pin 2 (+V) and pin 3 (0V) and when ignition was turned on it lit up and stayed lit up even with the engine turning over. So it looks like a new G40 is in order.
                          Cheers, Brian
                            #28
                            Good - well you have tested it correctly now so good luck with some care on renewing the sensor.
                            You MUST have a counterhold for the camshaft pulley when loosening or tightening
                            Use a couple tywraps to hold timing belt onto pulley for duration of the swap.
                            • BrianSmith_S2
                              • Jun 2005
                              • 1342
                              #29
                              Just replaced the G40 carefully in around 2 hours..... but she still wont fire up
                              Just checked the blink codes and the 2113 has been replaced by a 2111
                              engine speed sender G28
                              • BrianSmith_S2
                                • Jun 2005
                                • 1342
                                #30
                                Managed to borrow a scanner from a forum member tonight.
                                came up with 3 codes
                                00513
                                00515
                                00518
                                Erased them then and repeated scan procedure and only 00513 returned.
                                Replaced G28 with a spare sensor but still no joy, she cranks over very easily but doesnt fire up, just giving out a 00513 after each attempt
                                Any ideas? im running out of time for ADI tomorrow
