Welding timing pin on flywheel
  • terrybullwon
    • Mar 2006
    • 8782
    Just use it as is alex it will be fine
    Chef
    • 20Vcqdriver
      • 829
      When I had the 7A in mine a bolt dropped through the timing aperture and sheared the timing pin off, fortunately both the bolt and pin fell out through one of the holes at the bottom and my extremely skilled welder at work, welded it back on through the starter aperture. lasted 18 months until the 20vt went in so can be done but if its ok now leave it..
      1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
      • A80Avant
        • 10873
        • Country: Greece
        i would go with the above, if you are not going to use any aftermarket ECU that potentially has issues reading the pin, just leave it as is.
        • rs200
          • May 2009
          • 1398
          • Home: Croatia
          don't be stupid like I was and weld it.
          look what I done second time when it happend's to me..
          so take engine out and take a fly wheel out...
          buy another pin in audi shop... here is the number... remember , pin must stay 1cm out from flywheel
          than drill the whole on other side of flywheel (go into machine shop) than you will come on other side of broken pin, and kick them out.
          put new pin on same place.. and must be 1 cm out...
          so now you have a whole on the oder side.. put some iron pin and polish the other side..
          I think that you understand me...
          • driftin jo
            • Sep 2007
            • 2222
            Originally posted by quattro
            I get your point but 8kg aint exactly a lot for a good weld now is it........
            Consumption of Beer seems to have messed up my equation , it's not 8kg it's 80kg ! I thought it didn't sound very much when I typed it . So you can see the little pin has to endure quite a lot during it's lifetime .
            • quattro
              • Dec 2004
              • 768
              #21
              Can you show your working out please, for info....
              Probably the longet S2 project in history EVER!
              • Fat Audi 80
                • 10547
                I make it 200kg from here:
                Input the mass, radius, and velocity, and our centrifugal force calculator will find the centrifugal force and centrifugal acceleration.
                I was assuming the flywheel has a radius of 0.2m at 7000rpm and the pin weighs 0.02kg
                The Perfectionist
                • quattro
                  • Dec 2004
                  • 768
                  #23
                  what value do you put in Linear speed
                  • driftin jo
                    • Sep 2007
                    • 2222
                    The flywheel has a radius of 140 mm and it was assumed the pin was 10 grams , these figure entered into your link page gives 76.7115 kg-force , so I would say I was about right at 80 wouldn't you.
                    • Fat Audi 80
                      • 10547
                      The Perfectionist
                      • A80Avant
                        • 10873
                        • Country: Greece
                        #26
                        question: if you add 10grams and not balance it, wouldnt the extra 80kg have catastrophic results to the engine?
                        also when you are welding it, you are probably adding much less than 10grams, as the pin is already there, you are just reinforcing it.
                        i ask this, cause in my case, we possibly did reinforce and definitelly added material to the flywheel. So how bad is the extra 80Kg? can someone say?
