At 1000 RPM it has a hard time "seeing" the reference pin, so it runs rough, I had a friend helping tune and thinking it might be a coil related issue settings were played with and a coil was turned to continually fire, thus cause the coil melt down.
With the new coil installed and a standard base map, the car runs VERY smooth above 1500 rpm, in the lower rpm it still has a hard time seeing the reference pin, Marc has suggested welding material to increase the size of the pin and that is probably what will happen. If you have a solution I am ALL EARS
