Volvo K24 turbo in audi application.
  • Ruffiano
    replied
    Correction max tq was before 4k max rpm was 4.5k
  • andy10v
    replied
    Sounds good.
    Anybody has any luck finding these in the uk?
    PRJ do you intend to do anything for the 3b?
  • Ruffiano
    replied
    Ps my max hp was hit just before 4k rpm
  • Ruffiano
    replied
    New from the dealer(stealer)they are750 usd they sell used from 150-500 usd, then add an Audi hotside
    my best awtq number was
    359.3
  • prj
    replied
    Originally posted by Rocco
    1/3 of the price?? buying new too?
    Well okay, maybe 1/2.
    And no, not new, that's the thing - there's plenty of these available compared to K24-7200's.
    I need to make some sort of a generic chipset for this turbo though. I don't think running RS2 chipsets will be very good with it.
  • Rocco
    replied
    replied
    Be interesting to see what sort of air temps are in play at 1.9bar on the ovlov turbo - maybe it will choke a little more than RS2 item - then again - maybe it won't - has anyone got a compressor map for the Volvo 7400 turbo ?
  • prj
    replied
    If it's running 1.9 bar boost, I don't see why not.
    replied
    nice result, will it deliver the torque of that an RS2 turbo can?
  • prj
    replied
    your Volvo turbo spools quicker than the oem k24 7200??
    Pretty sure it does.
    I will put on my turbo in a few weeks and map it on a dyno.
    So basically this is a turbo that spools faster than the RS2 unit, gets as much horsepower as the RS2 unit and is 1/3 of the price.
    Of course it's not fully bolt on, but we got a winner.
  • Rocco
    replied
  • Ruffiano
    replied
    Yes pump gas, and at 4500' above sea level
    replied
    This old chestnut... Reckon on multiplying wheel HP on quattro by approx 1.25 for a flywheel estimate. Therefore 295 at the wheels should be in 370 territory. If it spools quicker than RS2 turbo then job is a good un.
  • Costash
    replied
    More like 400
  • Rocco
    replied
    Originally posted by prj
    Nice.
    You are running pump gas, right?
    290-300whp with K24-7000 spool is my target as well.
    WHP should be around 360 crank power?
