wot sensor is this???
  • avnts2
    • Apr 2004
    • 36
    hi ,
    can anyone assist in a sensor identification , this appears to be oil sensor of
    some kind , it sits on n/s of engine block pretty much inline with the main radiator , and is the lower of the two sensors in that area ,with a single wire
    coming from it . ? leaking oil so can assume its oil pressure or temp ??
    or ???
    95 aby engine..
    cheers dave
    tayside ..
  • s2avant
    • 2426
    The lower one is the 1.8 bar oil pressure switch. Replace it ASAP. They're only £7.63 + VAT from us main stealers but can be a bit of a swine to get to if you have got the right socket.
    I say replace it ASAP as whilst pulling 140mph (on the runway at the bottom of my garden) the top blew clean of mine and sprayed oil everywhere. Apparently I looked like a red arrows display team as I passed a work colleague.
    Ben
    • avnts2
      • Apr 2004
      • 36
      Ben
      cheers ben , al give the stealers/swines a call tomorrow , no dout it wont be in stock , .. have found this only after a close inspection , due to a puzzeling
      oil loss , sounds like a job for the weekend , so some carefull driving required , not sure what will be harder.. !!!
      many thanks ben !.
