Ok, here's the story:
I bought this turbo on Audifans for $700. The previous owner had the turbo removed by Marc at EFIExpress. Both the owner and Marc stated the turbo was good without any smoking. I have the turbo shipped to my house where it sits in a padded box for 2-3 months while I get the rest of my kit in order.
Last Saturday, I finally get it installed
On first fire, it started up fine. Once things started warming up, CLOUDS of white smoke came out the turbo. Definitely smelled of oil and not coolant. After about 5 minutes, the smoke subsided. We took the car around a bit and there was no smoke under boost or anything else.
So we figured it must have just been from us installing it.
I don't drive it on Sunday, but I do on Monday for a short drive (about 2 miles).
It doesn't smoke at all when I first fire it up, but after a few minutes it starts smoking. By the time I get to the end of my 2 mile trip, it's stopped...
It does it again on my ride home 9 hours later.
I don't drive it on Tuesday, but I do again yesterday.
No smoke on the drive out to the train (again, 2 miles). But smoke on the way home. Same situation as before: it doesn't happen at first turn over, but it does a few minutes later. Then after a few more minutes, it stops.
I didn't drive it today either. It was nice enough to walk. All in all, I've only put about 10-15 miles on the car since I put the turbo in.
Someone suggested that the turbo sitting in the box has dried out the seals and when I turn the car on after a cold night, the turbo burns off the oil that's leaked through (after the turbo has gotten to temp) until the seal softens up, expands and seals off the leak.
Now, I'm wondering if I put enough mileage on it in one big lump, if it'll go away. Maybe the seal will relube itself.
If not, I kinda want to just rebuild it myself rather than spend another $350-450 to have someone else rebuild it for me. What would you guys suggest? All the other Audi forums have told me to come and ask here specifically. They say you guys are the best when it comes to this stuff.
