Some may have read my fuel pump post and my dead S2
I replaced the G40 only to find the old one was fine
Now going back to basics and fault finding the wiring and sensors.
First check was to check the ECU was seeing a signal line from the sensors. I get continuity between pin 2 on the
G40 sensor to pin 8 on the ECU
G28 sensor to pin 49 on the ECU
G4 sensor to pin 47 on the ECU
Second check was resistence check on sensor G28 and G4
G28
0.97k between pins 1 & 2 (sensor disconnected from wiring)
0.95k between pins 1 & 2, 2 & 3
G4
Third check with ignition on i checked voltages
G28
0.8V (0.9V when turning over) across pins 2 and 3, 0.1V across pins 1 and 3
G4
0.1V (0.1V when turning over) across pins 2 and 3, 0.1V across pins 1 and 3
Do these look ok?
I turned engine over today with fuel pump relay cover off and it does energise. I was told at ADI that someone had also done fuel pump test, i.e. fuel lines disconnected and ignition on and they saw fuel spray out, but it didnt pump when connected, i.e. it may have not worked under full load/pressure. Gonna buy back the fuel pump i returned to G&S last week
as im running out of ideas
G28
G4
G28
G4
Do these look ok?
