Valeo Radiator?
    Valeo Radiator?
    Anyone ever used a Valeo Rad as an alternative to the Behr or the POS Nissens?
    Similar prices to the Behr & Nissens
    £77.35 + VAT for the non-aux rad model (377 x 480 x 40mm core)
    £141.78 + VAT for the aux rad model (380 x 480 x 40mm core)
    Any comments?
    Alex
  • Nuvo
    • Nov 2003
    • 3825
    The heater matrix is a Valeo item, so they are an OEM at least. Based on that alone, I would expect the quality of the main rad to be good.
    Never fitted one, so I can't vouch for them though.
    • Rusty
      • 18953
      As above, Valeo make a lot of OEM stuff so I'd hope that quality was OE.
        Good stuff Rob, if they're an OEM well I might give this a go. - since I have deleted my aux rad and the core is the same size, the non-aux option is agood option price wise me thinks.
        • s2driveruk
          • 12696
          sounds like a good option Alex, let us know how it goes
          1992 3b S2 Coupe
          • Rusty
            • 18953
            No need to get an aux. rad. for the British climate, I think you're referring to getting a 7A version without the front pipe, correct?
              Nope the 7A had the aux rad too, this is the rad for the NM engined coupe quattro I believe.
              • s2driveruk
                • 12696
                hmm, not sure as i have a 7a rad hose which doesnt need a bung from memory when i deleted the aux...
                1992 3b S2 Coupe
                  think thats maybe off a 10v car, all the 7As i've seen have had the aux rad.. in the UK anyway
                  I've just ordered one of these non aux rad Valeo rads for £100.00 delivered so we'll see how it goes
                  • Jon441cc
                    • Dec 2005
                    • 2061
                    Agree with Alex, 7A's also had aux radiators.
                    Keep us posted on the Valeo Rad Alex
                      I am pretty sure that when I renewed my radiator (many years ago) it was a Valeo item and it has served well since then.
                      • driftin jo
                        • Sep 2007
                        • 2222
                        Be careful it's not just the size of the core ,its the fins and the size of the gaps in between them , my s2 rad has much larger spaced fines than the other non turbo rad I have lying round.
                        • MGaz
                          • Feb 2008
                          • 698
                          Any comments?
                          Alex
                          I have a Valeo on my car. was on there when i bought it. seems fine to me. so far so good anyway.
                          C4 A6 AEL avant quattro: daily
                          TYPE-85 Coupe Quattro: clicky
                          2.5L GTi engineering RE2500 190hp.180lb
                          Schrick 272 cam
                          C A C 2.5" T304 Exhaust
                          ITG filter
                          • Audi Parts Guru
                            • 1317
                            Or you could get a BEHR-HELLA unit. OEM quality and a good price too
                            Part number 8MK 376 711 281
                            • Rusty
                              • 18953
                              Fair enough. Non Aux rad style is much neater, need the lower hose to go with it too, then it's all neat and tidy.
