Im in Germany at the moment so a long way from home.
This morning i was driving the car and all a sudden loads of steam pored out of the bonnet. I pulled over and opened the bonnet.
The header tank cap had worked its way lose and was chucking out loads and loads of water.
I waited for a while, topped up the water and tried to bleed the coolant system. It was working fine up to about 90c when lots of pressure pushed most of the water out of the expansion tank again. I also noticed a large amount of bubbles from the bleed screw on the rad.
I tried this a few times with the same thing happening each time.
On top of that there is also plenty of white smoke out the exhaust combined with splashes of water..
Im pretty sure that the HG has failed and that cylinder compression is pressurizing the coolant system. This must have made the cap leak in the first place.
If i switch the engine off, let out pressure form expansion tank, switch engine on again for a short while it builds a little pressure on the bottle. Not much but some...
Lets hope the ADAC can flat bed me home...
But this method feels reasonable.
