Fuel drain
  • s20ale
    • Aug 2004
    • 476
    Fuel drain
    Anyone know how to drain the fuel tank quick and easy, as my car has sat for over 18mths (shocking i know) but having finally made a crank lock tool, changed the cam belt and all other stuff in there i would like to drain the fuel and start a fresh.
    Any help would be appriciated thanks.
    Oh forgot to add its an ABY avant.
  • driftin jo
    • Sep 2007
    • 2222
    Undo the fuel feed under the bonnet attach a suitable pipe and hot wire the pump .
    • driftin jo
      • Sep 2007
      • 2222
      Just in case you don't know the brown wire to the pump is earth NOT live , many people make this mistake when making wiring to pumps .
      • gnutz2
        • Aug 2006
        • 928
        I would take one of the fuel lines off the fuel rail, put it in a suitable fuel container.
        Then remove the fuel pump relay and place a link between the normally open contacts. You would ideally use a short wire with two male spades crimped on, but i usually shove a bit of bare wire in.
        The ONLY S2 Golf!
        10.42@138mph
        • gnutz2
          • Aug 2006
          • 928
          Link relay pins 87 to 30.
          The ONLY S2 Golf!
          10.42@138mph
          • s20ale
            • Aug 2004
            • 476
            Cheers Barry, just the info i needed and it worked a treat.
