Has anyone got any detailed information about the 10v Turbo KG engine...?
I'm looking mainly at it's compression ratio, piston crown cc and turbo/intercooler set up etc... Also the set-up of the crank timing and knock sensor... We've got a KG lump here, and the piston crowns are markedly different to the WR, it ran a water cooled KKK24K and has two crank/timing sensors on the front of the block over the flywheel. Additionally, it appears to have a knock sensor in the head mid-way along the block.
We're looking, in time, to set the (rebuilt) engine up with EFi and any information will be gratefully received.
Kind regards
Ian
Kind regards
Ian
