Guys i know at least Jamo is aware of this and it wont bother the cast guys too much more the tubulars but will have an effect for sure.
over the last couple of weeks i have been testing at higher boost levels and in general been using higher boost more. last week i did a motorway run and i think the resulting boost runs have had an effect on the manifold wastegate tube.
i have been running the stock exit pipe from the wastegate and now feel the bottleneck it causes has caused high egt in the wastegate feed tube causing the metal to become softer eventually cracking. now with cast it wont be as evident but surely it would cause a generally higher egt in the full cast unit.
the beauty of the tubes is its 2 hours to strip the full lot off from start to finish. today ill get the manifold welded up but i need to get a wastegate tube to prevent this in future. i dont think it mattered at lower boost but at the higher levels say 1.7 and above it matters
does anybody make these to replace factory pipe.
cheers
cheers
