me neither. however im still open minded about holset and individuals quests for imrovements
so far its a bit like saying my new nike trainers are faster than the old adidas ones i have.
i think ill end up with my current opinion of compromise and if its around the same size and specs itll do about the same but i want to be enlightened about holset.
I have to agree that an HX35 is similar to a 3076. I run an H1C on my 3b. The H1C is nearly identical to an HX35 and the power level is like a 3076 so far. Maybe once I get over 1.5 bar it will be different.
According to wheel sizes the hx35 is almost same as the gt35r. H1c have most of the times smaller compressor impellers than hx35.
However I thought that it is interesting to see that a turbo that is between the gt35r and the gt40r spools as the gt30r. Everything else is either way setup dependent and need to be proven. I hope someday to make it to a dyno and have more facts.
35r is what...61mm? an Hx35 is something more like 56mm if I recall correctly. That is the same as my H1C as measured by me with a caliper (I have the biggest H1C, but with a 12cm^2 exhaust housing from an HX35).
actually, now that I think about it I believe its 57mm for the big H1C compressor impeller. Roommate who also has a big H1C confirmed this.
I think part of the reason that these turbos spool relatively well is because their wheel design (exhaust and comp) is superior to garrett's (not the new billet wheels though).
Compressor - Turbine
HX35: 56/82 70/60
HX35: 58/82 70/60 (rare)
HX35/40: 60/85 70/60 (Hybrid)
HX40: 56/82 75/65 (8 Major Blades on the compressor impeller)
HX40: 60/85 75/65 (6 blades called Pro and 7 blades called Super 40)
Now you see where the impeller design plays a big role. All this time we comparing Holset turbos with 1-2 steps smaller Garretts. You see now what makes them (Holsets and in my opinion Schwitzer nowadays) so special....similar spool (or a bit laggier) with smaller garretts and big HP as big garretts.
In terms of high HP we want as big as possible both sides. Critical in HP number is maximum flow of the turbocharger that is always restriced by the Compressor inducer diameter and the turbine exducer diameter.
Bigger compressor exducer means more air flow at low turbo RPM.
Bigger turbine inducer means better spool at low exhaust gas amount.
Put now all over that the impeller design and you get the idea.
If you mean HTA, then yeah...those things are awesome. Otherwise, Holset is the only way to go IMO in terms of blade design. Its funny that Holset's design was better 20 years ago than Garrett's was up until just recently.
CP have dyno results on these engines, some have been posted some haven't, I've seen quite a few and the results speak for themselves
The new Billet HPA wheels are smaller but flow more and are quicker spooling, granted being billet helps
I would like to see these dynos....
You are talking about CP billets dont you?
Garrett GTX (Billet) are only for large frame GT45 available).
Forced Perfomance HTA wheels are old design but billet (at least the ones i have seen in the net)
About inducers (whatever impeller design) there comes a point where the max air that can be sucked or pushed through a hole is achieved. The compressor inducer and turbine exducer point out the margins you can go. The middle and how you reach for these margins depends on the impeller design.
...and since these came up take a look at this from motorgeek. Top HP same (allmost identical). The billett help only spool up by about 200 RPM and this is not design related. it is because of the weight. The design of a compressor impeller has minor effect on the spool up time. HTA or not the turbine is the same.
So here we go. Hank, Javad and I have been brewing this up for a few months and it finally came together on Thursday 5/27/2010.
The goal: Compare the new billet wheels on the HTA turbos to there traditional counterparts. There is a lot of speculation out there, lots of data on Evo's, but...
i thought that the larger major of the holset impeler only allows highee boost levels rather than anything else(extended tip). yes they can run 3+ bar of boost and that way you have all those horses.But as i mentioned before, my hx40 did not seem faster than my 3076 at 1.7 bar. timing is the same and he latter has juice up high on the rev range.
billman, your old setup with the hx40 with the 56mm impeller,at 1.3bar made around 350 hp on the same area whwn my 3071 made 420 with about 1.85 at the redline. i dont think the holset thwn could get +100hp only with 0.5bar increment and nothing more.
but that ia only my hunch.
the 350 hp with is only a guess since we where not on a dyno but it was faster than my K24 7200 chipped. So i guess it was more than that....who knows.... but for sure 0.5 bar at the redline can shift yout compressor map from 68 or 70% effiency to 78% efficiency and that could make then maybe more that 80hp difference.
