Finally remapped!!
  • DamoM
    • Feb 2005
    • 352
    Finally remapped!!
    Finally got MRC to remap my WR ur quattro (now fitted with a 20v ABY, stroked to 2.5l etc etc) and got a nice end result of 455bhp and 500lbs!
    Too wet to try it out properly but feels very nice.
    *1986 ur quattro,2.5 stroker
    *1995 Nogaro Blue RS2,Md357
    *1991 RR 20v quattro
    *2000 Nogaro Blue RS4,RS6 turbos,tubulars,custom 3" downpipes,Miltek,FMIC,big injectors,RS6 big brakes,RNS-E satnav/TV,592bhp/600lbs
    Holy cow! That'll go some! DJones' 2.2 is fast enough but 500ftlbs!
    • DamoM
      • Feb 2005
      • 352
      Got a coil pack that is intermittently misfiring at 1.2 bar (it's mapped to 2 bar!) so just changing the whole set now.
      Gonna get some road figures on it with the drift-box as soon as it's dry!
      Everyone kept saying that strokers don't rev but this pulls nicely through to 7500 rpm!
      DJone's one is a work of art though! Mine definitely isn't!
      • EspenW
        • Apr 2007
        • 1534
        • Country: Norway
        Sweet
        Some Dbox in gear figures from 2nd, 3rd and 4th in addition to for example 0-100mph figures would be smooth.
        1994 80E Avant
        1986 2L Golf 2 on Alcohol
          It's a myth, Mine revs to 7300 no problem, I don't need to go higher.
          • DamoM
            • Feb 2005
            • 352
            Originally posted by EspenW
            Sweet
            Yep I'll do some when the rain stops!
            You do all of your times on alcohol??? ha ha
            • EspenW
              • Apr 2007
              • 1534
              • Country: Norway
              Oh yeah, str8 up 85%
              1994 80E Avant
              • DamoM
                • Feb 2005
                • 352
                You're right. I had that when I put the 6 speeder in the ur quattro. There were so many 'experts' that said do this and do that when in actual fact so much of it was BS! Therefore I just decided to do it myself and learn along the way. That way I discovered that some of the people who had said they had done it most certainly hadn't!!
                The power graph shows strong power all the way to 7000rpm, with some (expected) tail off but nothing different to any other power graph i've had done!
                • Billman
                  • 4129
                  are you gonna post the graph? What turbo and cams??
                  Nice results by the way!!!!
                  Go Holset or Go RS4
                    That's really good, I need to check your thread again for the stroker thread
                    • DamoM
                      • Feb 2005
                      • 352
                      That's what I'm on tonight then!!
                      • DamoM
                        • Feb 2005
                        • 352
                        Here it is:
                        It's got an RS2 inlet cam and a 7a exhaust cam. Turbo is an MD357 from Turbo Dynamics (the same turbo that DJones runs).
                        • prj
                          • Mar 2010
                          • 6308
                          You are swapping between E85 and Pump gas?
                          How exactly?
                          Or am I missing something?
                          • DamoM
                            • Feb 2005
                            • 352
                            Here it is:
                            • DamoM
                              • Feb 2005
                              • 352
                              How exactly?
                              Sorry. I was just trying to point out that I was going to be drinking something with a high percentage of alcohol tonght! I run pump fuel.
