Finally i did it ,3B to RS2 setup dyno results
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    #31
    Originally posted by A80Avant
    the 3071R runs out of juice at about 5500-6000 at most with the 0.63AR from old logs on my setup(ADU cams). Still better than the rs2 turbo and i used to get 600+ nm of torque, so not much different in pull. It also has to do with mapping. If you map to give 2.5bar on the 3071 on fast spool, if your pistons and engine can take it(as the turbo sure can) you can get it to give more torque than the rs2 turbo. I used to have 2.1bar overboost and 1.75-1.85 to the red line, but the torque curve was going down pretty fast after 5000rpmish
    3076 though a whole different story!
    Vasilis, what would be your favourite?
    gt3071 0.82AR or gt 3076 with 0.82AR ???
    • A80Avant
      • 10873
      • Country: Greece
      #32
      either 3076R with 0.63AR OR 0.82AR
      the 3071 with 0.82AR is of no use, because it would be roughly the same as the 3076 with the 0.63AR and produce less power than that.
      currently i like the 0.82AR on my 3076, which pulls easily through to the 7000rpm area
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        #33
        and with your current turbo,wich is it your best spool up?? full boost by 4000rpm with a 2226cc engine and original crankshaft??
        • A80Avant
          • 10873
          • Country: Greece
          #34
          crank has minimal to do with it. i have 2.1bar on 3d gear at 4000rpm and 3750 on 4th
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            #35
            this is a very nice spool uo too
            better than i was specting to hear:mischeif:
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              #36
              in a spanish forum dedicated to tune the cars as "racing" not exterior ,they said me that my car should be useless...because the max power at 5000rpm it is useless and it seems like a TDI engine
              the people who answer me has cars like Focus ST with 260hp,Impreza 99 year STI with 330hp,or other worse cars
              what can i say?? what do you think guys? it is useless?? a pair pf persons there said me like it is tuned like a rally car ¡¡ with very nice numbers and easy power to use
              here a better quality image by PDF:
              • Rocco
                • Aug 2007
                • 6393
                • Country: Spain
                #37
                and here both dyno results of one with my car and the Hamon Motors software with my friend´s car "Manuel Garrido" forum member with stock turbo and MTM software + RS2 iC and full Super sprint exhaust sistem ,305hp ¡
