RS2 speed in different gears
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    Anyone has this info?
    i need the speed of an rs2 with ADU cams on 5000rpm on each gear. If any of this info is available please let me know!
    thanks
    vasilis
    Engine components make no difference.
    From workshop manual the calculation is this:
    V = (n / iov) x (ua x 0.06)
    v = speed
    n = engine speed
    iov = overall drive ratio (gear ratio x final drive ratio)
    ua = rolling circumferance of tyre
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      well what are the proper values then?
      i have : ua=629mm
      gear ratios already known
      engine speed: 5000rpm
      example: 1st gear:
      V= (5000/3.5x0.71) x 629x0.06=38494
      obviously the circumference needs to be in m? cm?
      gear ratio x final drive ? final drive being the 6th gear?
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        im not doing something right, cause if i use m for circomference, it seems ok for 1st gear but it brings me to 140km for 2nd gear and 201km for 3d gear at 5000rpm, which is not correct
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          oops!
          wrong calculation for final drive!
          • A80Avant
            • Sep 2005
            • 10873
            • Country: Greece
            using the correct final drive, values are too small again, so im either doing it wrong(likely) or there something else..
            here are the gear ratios
            http://www.s-cars.org/postnuke/modul...rder=0&thold=0
              circumferance needs to be in Meters
              Looks like you are using diamter in mm @ 629 which is 1.98m circumference.
              so you have:
              1st 5000/14.8 x 1.98 x 0.06 = 40km/h
              2nd 5000/7.77 x 1.98 x 0.06 = 76km/h
              3rd 5000/5.43 x 1.98 x 0.06 = 109km/h
              4th 5000/4.23 x 1.98 x 0.06 = 140km/h
              5th 5000/3.53 x 1.98 x 0.06 = 168km/h
              6th 5000/2.92 x 1.98 x 0.06 = 203km/h
              R 5000/14.2 x 1.98 x 0.06 = 42km/h
              • A80Avant
                • Sep 2005
                • 10873
                • Country: Greece
                aaaah yes.
                629mm is my tyre-wheel diameter.
                hmm it seems a bit low to be 203 only in 6th gear 5000rpm... can i go from 5000rpm to 6500rpm on my car from 203 to 280km?
                  6500rpm in 6th is 264 km/h - 280km/h is 6880rpm
                  7200rpm in 6th is 293km/h
                  so it is all about right. Speedos in cars tend to over-read by 5-10%
                  • driftin jo
                    • Sep 2007
                    • 2222
                    judging by the diameter of tire you have given (629mm) I take it you are using a 215/40/18 ?
                    The reason I say is this is slightly less than the stock tire diameter of (632mm) for a 205/55/16.
                    The thing is that with the stock tire the speedo reads too fast by about 5mph / 8 kph .
                    The tire you are using will increase this error even more .
                    I have a satellite speed device that is guaranteed to .5 mph and my S2 speedo over reads by 2.5 mph and I run 225/40/18 (637.2mm) diameter.
                    So unfortunately this means your not going as fast as you think .
                      AFAIK he's running 245/35 18s
                      • driftin jo
                        • Sep 2007
                        • 2222
                        Even worse then as 245/35/18 is (628.7 mm)
                        just a little
                          so a 235/40 18 would read just about spot on then I guess
                          • driftin jo
                            • Sep 2007
                            • 2222
                            yes , speedo would be good with this size . probably read about 1 mph over , Close enough
                            • A80Avant
                              • Sep 2005
                              • 10873
                              • Country: Greece
                              yes, that is what i use, 245/35/18 so its very close to 629. i think a couple of tyre calculators bring it up at around 628+ so no big difference.
                              Good info Error, all vems users with a speed sensor can now use this calculation!
