Moisture Trap and Manifold Absolute Pressure MAP info
One of the problems with the AAN and low boost is the moisture trap (on the firewall on a C4 S4 and down by the ECU on a C4 S6). The clamps come loose on the moisture trap and the ECU fails to get the proper boost (or vacuum) pressure. I would put money on this being your problem over a bad MAP sensor.
Moisture Trap info:
MAP sensor info:
Moisture Trap info:
MAP sensor info:
