HI every one
I am registering two fault codes:
1111 (Blink Fault Code), VAG1551/2 Fault Code Number 65535 Engine Control Unit (ECU) Defective memory circuits, incorrect Checksum for EPROM(s) (this can occur on some modified ECU's) Check ECU ground connections, Replace ECU?
2111 (Blink Fault Code), VAG1551/2 Fault Code Number 00513 RPM sensor Open or short circuit, Defective sensor & cables, metal fragments on flywheel teeth
Is this true about modified ecu's? That they can pop code 1111. I don't know if my ecu is chipped or not?
Any help is appreciative in the path that I should check to correct the problems.. I am searching hard.. but I will take what I can get.
Josh
Josh
