Can anyone advise me on an aftermarket engine management system for the AAN engine.
AAN aftermarket engine management advice
Audi Sport Project, rally Quattro Coupe, 100 Quattro estate, Viva GTTags: None -
There are many people running Vems but there are many options it depends how much work you want to put in and what your budget is.
I can highly recomend Tatech works with your stock sensors if you want and you dont have to weld to your fly wheel to get the the signal from your fly wheel like vems seems to have to.
Other brands are Haltec, Nira, Autronic, 034, KMS, DTA and a few others i have forgotten.ChefComment
Wile your on the subject of after Market engine management is there one that offers fly by wire throttle . It would take away the hassle of finding a cable to fit when going reverse inlet manifoldnever set your expectations to high that way you are never disapointedComment
ahem...MegaSquirt3.
People slate it but if you actually look at the spec. Of the unit and the support out there. Plus megatune is easy to use and written in proper english.
Need to weld a toothed wheel to your front pulley though. Or buy one ready done from 034 with sensor bracket and all.Volcano ABY coupe
AntComment
