Bought my first S2 and noticed that the Oil and Water temps seem to take awhile to rise. Water after a 15 minute steady drive to work on a morning gets almost half way between 50 and 90. Oil Temp just to say moves off the lower temp.
mine sits at about 80. always thought that was a bit low. going to blank off the aux rad and see what effect that has.
Where it sits isn't really a worry unless very low as the gauges read different from one to another , its how long it take to warm up that tells you you need a new thermostat or not.
It doesn't matter how big or how many rads you run if your thermostat is working it will warm up quick .
