TRying to run an ABY ran fan in my 7A.
I've got an ABY fan loom and resistor pack on the way to me.
As a temporary measure to ge the car running i tried bridging the two positive feeds to the existing rad fan together since the ABY fan only has two terminals. I've tried to test the fan etc to see if it works and keep blowing the 30A fans fuse at the fuse board. Now i guess thats because it draws a load more current than the 7A / 3B unit?
Then it dawned on me that the ABY fan set-up is designed to work with the afterrun pump as well as the two stage cooling speeds. So in my set-up, will it be able to just ignore the fact that there is not after-run temp sensor and just use the rad thermo switch to trigger the middle and high speeds?
I'm also hoping this is just plug and play in the 7A - any BTDT on a 3B?
I guessed there will be a big *** power feed from the fuse board, a fuse holder, relay and then the loom out to the engine bay with the resistor pack?
also a good opportunity to install a tidy override switch into the dash i guess
