A question on 3b boost ????
  • ian4455
    • Nov 2010
    • 787
    Here's the specs i found, so a standard 3b should boost at 1.8 Bar ??
    3B System Specifications
    Firing Sequence 1-2-4-5-3
    Max Horsepower (bhp / kW)
    220 / 162
    Max Torque (lbft / Nm)
    228 / 309
    Compression Ratio 9.3 : 1
    Max Charge Pressure (bar) 1.83
    MAP Operating range (bar) 0 - 2.0
    Max Fuel Pressure (bar) 3.0
    ECU Part Number 895.907.404 BA
  • Costash
    • 878
    • Home: Romania Current: United Kingdom
    It is in fact 0.8 bar not 1.8bar !
    • dm80
      • Apr 2005
      • 812
      0.8 bar
