Ive spent the day changing the thermostat it opened at close at boiling point, but was ment to open at 86*c.
So I was confident I`ve fixed the car only to fire up and find that it still runs hot I wonder if the water pump is working correctly if at all?
The bottom hose from the thermostat is cold as well even though the bottle is steaming hot the guage is saying 100 but the pipe is cold it has collant in it and is bleed.
on the bottle should I see coolant being pumped in at the top?
