Hi guys,
I'm looking to run a very large turbo and as we all know they tend to be very... laggy!!
So, i had a brain wave and wanted your thoughts on it..
If i build a tubular manifold that tapers as it gets towards the turbo do you think this would reduce the lag?? My thinking behind this is that as you force air/gas through a smaller gap it increases in speed and pressure and thus would make the turbo spool quicker... or would it???!!! Also there is the problem that in doing this it will most likely cause more back pressure in the manilfold which might have an adverse effect due to not getting the gasses out of the engine quick enough so i'm unsure if its a sound idea or not....
