Max HP on standard CR
  • URSIMPO
    • Jul 2008
    • 431
    Probably been touched on a thousand times..
  • terrybullwon
    • Mar 2006
    • 8782
    Totally depends on the build.
    Chef
    • URSIMPO
      • Jul 2008
      • 431
      standard head, uprated rods. gtx30 turbo. im currently running 420hp with no issues. but i like the idea of the new Garrett - and money sat doing nothing in the bank is so passe.
      • driftin jo
        • Sep 2007
        • 2222
        It really depends on what fuel you will be using and the head work etc , if you run on alcohol for instance you could make huge power on standard compression ratio.
        It's not really what the maximum would be possible In terms of HP its more about what is advisable for a given set up / desired HP level .
        I would say if you plan to go over 500 HP it would be advisable to drop the compression to 8.5/1, but like I said if you run high octane fuel then more HP would not be an issue at standard CR.
        • URSIMPO
          • Jul 2008
          • 431
          tescos 99 or v-power always. i don't really want to muck around with the low down power - the s6 is poo enough as it is. Alcohol is out - I can't be bothered with faffing about pouring JD in to my car instead of myself.
          • driftin jo
            • Sep 2007
            • 2222
            E85 is 85% alcohol
            • URSIMPO
              • Jul 2008
              • 431
              Even worse: only available in Scottish pubs.
              • Bram
                • Aug 2006
                • 2582
                I believe when using the right fuel (good RON 98), good coils (e.g. 034MS HO) and spark plugs (Denso irridium) you can run 550HP safely with standard compression like I do.
                Jyrki advised me to keep stock CR for my setup (stock head with re-clocked cams) at least, which should be able to reach 530-550HP.
                • repo
                  • Dec 2004
                  • 893
                  I took a part 29 000 km driven 630hp/790Nm engine a couple of years ago. Stock pistons were in great condition, only a couple of rings had lost their chrome coating a while earlier. Which was the reason I took it a part.
                  So, +600hp easy with proper setup and pump fuel with stock pistons. And hence stock compression ratio.
                  Swedes use the Booze and 10-11:1 C/R and make tons of horsies with tons of boost, so just like Chef said, totally depending on Your setup.
                  • Acidburn
                    • 13459
                    Interesting to know, I know a lot of the fords boys are starting to do high compression cossie engines but didn't know of any audi's yet.
                    Take it the biggest weakness in the engine is the rods? once these are changed anything else done to the engine is a bonus?
