Hi guys,
My electric water pump keeps on running constant. I have pulled up ECU
fault codes and comes up all Clean. Changed both switches on water jacket
I.e Thermoswitch & thermo sender but still keeps on running. the only way
to switch it off is either removing fuse no: 19 or disconnecting the connection to the electric water pump.
Any suggestions would be appreciated
and is
