i have been talking to my mechanics and it seems that the 0.5mm oversize valves are somewhat too small of an upgrade if you are to do an upgrade to the valves anyway. SO what other options are there?
largest available valves for rs2
There is absolutely no point in trying to fit larger valves in the 20v head. You would be much better off in getting the ports modified to increase the airflow. Just a few small modifications in the right areas of the port could make a big difference in air flowS2 Avant......fully loaded :rock: :bow: Slipper Wagons Rule !!!!!Comment
you can get 2mm oversize. I also agree with the consensus that you need port work before the valve upgrade will do much. I do think the 2mm valves would gain on a ported head vs the "standard" .5mm oversize. you will need new valve seats too if you go up to 2mm.Comment
You can get 2mm oversized for the intake but this is no good for turbo use only for n/a use as the flow balance between 2mm oversize intake (needs oversized seats fitting) with a 0.5mm exh valve (recut original seat) is just not suited to forced induction use.
You can get custom valves made in min quantities but by fitting a larger exhaust seat you are going to hit the combustion chamber wall and shroud them too much seeing no extra gains. Plus you would need to weld up the spark plug hole and rethread so you can fit the smaller motorbike plugs.
Stock valve size reworked will see around 10-15% gains on the intake and anywhere between 20-40% on the exhaust depending how drastic the port workup is. Fitting an oversized valve will push the intake to around 20-22% and the exhaust as much as 50% providing the port design is changed to accomodate it. Again the benefits will not be seen unless you have a correctly flowing intake manifold which does not restrict your new intake ports and a good flowing exhaust mani that does not choke the exhaust ports.
As a reference point attached is my I5 head that made 528hp with now new seat cuts for oversized valves but no new port work up yet so you can see the difference in port size.
hth JPUrS6 Stroker + HTA3586 =
Avantus.
A stock intake will kill the intake flow figures by 10% on stock.ported and 15% on 0.5 ported intake. Port match the intake and you can get 5-7% back. Going aftermarket reverse wagner and port matching will not kill any flow of from ported gains on either configuration.
Niki
Here's an example of seats from us supplier
