Right, its the golden question! Planning for now and the future...
currently, its pretty much stock apart from cone filter and s3 dump valve and re-mapped and i'd like to find some more power. the question is, what should i do!?
Currently, most of my money is going to refurbing the subframes, corners etc but id like to spend a bit on the engine performance if i can!
not going to lie, right now i cant afford manifolds turbo etc, but i was going to fit a new exhaust 2.5" to 3" (yet to decide) but also wouldnt mind anything else if its not going to rip my account to shreds (very unlikely!).
so far i've been looking at some cams and injectors.
First off...CAMS. i know theres audi standard cams from a 7a or NM? this correct? how much gain is this going to get?
Injectors...Seen some bosch race injectors (the light green ones) @ 450cc/min. I realise this will need a re-map atleast. Is the stock FPR 3.8bar? would a 4.0bar be needed? any other problems this could cause or changes needed?
Thanks in advance!
Will
Thanks in advance!
Will
Your turbo will be near it's limit now ,a larger exhaust will let it breath better so will spool up quicker which will help .
if it was me I'd make the following changes in the following order;
