What kind of power te expect
  • Evert Thomas
    • Sep 2007
    • 178
    Hello dear forum member:
    I'm building an S2 engine with the following specs:
    1. Turbo Garrett GT3071R Ar.50;
    2. engine SCAT conrods and JE Pistons (83mm);
    3. CAT cams, witht the following specs:
    - Intake 278o;
    - exhaust 251o;
    - Lift intake 1.145mm
    - Lift exhaust 995 mm
    - Spread inlet 110o;
    - Spread exhaust 120o;
    - Lift BDP inlet 2,4mm;
    - Lift BDP exhaust 0,5mm.
    3. Mechanic lifters in stead of hydrolic lifters, so i could run some more rmps;
    4. Hand made spagetti exhuast manifold;
    5. 3 Inch downpipe en exhaust;
    6. Bigger intercooler wicht reversed intake manivold (Wagner);
    7. DTA stand alone ECU.
    My question is, what kind of power (HP en torque) can i exepct?
  • Evert Thomas
    • Sep 2007
    • 178
    I almost forgot, the cilinderhead is ported.
    • terrybullwon
      • Mar 2006
      • 8782
      How many more RPM?
      Chef
      • Evert Thomas
        • Sep 2007
        • 178
        That i have to find out, but I think about 500rpm should be possible.
        • driftin jo
          • Sep 2007
          • 2222
          About 12 hp then
          • Evert Thomas
            • Sep 2007
            • 178
            Haha ok, well if i manage 1.000 rmp, that would be 24hp?
            • terrybullwon
              • Mar 2006
              • 8782
              I am pretty sure that garret is over and done by 7500rpm?
              Chef
              • driftin jo
                • Sep 2007
                • 2222
                What we are trying to say is there is not much point in extending the rev range if your not using a turbo with enough flow capability to keep the boost up at high rpm .
                I would say you could make ~470 HP but you would have made that before stock rev limit anyway .
                • Rocco
                  • Aug 2007
                  • 6393
                  • Country: Spain
                  i think that 750hp and 1000nm are possible , i have a "friend" with worse specs than you with the same turbo giving 523cv & 683nm
                  • Dan
                    • Jun 2008
                    • 1242
                    1993 ABY Coupe | BMW R1200 GS
                    A6 3.0 TDI Quattro (aka Sonic's 'ring support/cargo vehicle )
                    • Evert Thomas
                      • Sep 2007
                      • 178
                      I agree on the revs. I didn't changes the internals and lifters to gain higher refs, to be clear about that.
                      • prj
                        • Mar 2010
                        • 6308
                        Your hotside is tiny.
                        That hotside is suited for a 1.8 engine or smaller, not for a 2.2.
                        You will struggle to make any power at all, because you will get crazy backpressure.
                        Go 0.63 or bigger. On a ported head, I'd say 0.82.
                        • driftin jo
                          • Sep 2007
                          • 2222
                          If you take that you can make between 9.5-10.5 HP per lb of air per minute then like I said the middle of that would be 470 HP for this turbo . See compressor map.
                          But as Pri says .50AR is not a good for a 2.2 20v engine, so in this case you would probably only make 9.5 HP max per lb of air per minute as a result thus ~445 HP if you are lucky .
                          • Evert Thomas
                            • Sep 2007
                            • 178
                            Thanks for the reaction so far. I'm using my car as a racecar and chose this turbo for the fast spool up.
                            • rs200
                              • May 2009
                              • 1398
                              • Home: Croatia
